15 years agoHi Kaz,
Yes, I understand your point. Initially, I tried to manually reset these addresses. But, I was not able to reset both "read address" & "write address" at the same time (clock). Only one of them reset. Again, I was not sure why? So, I saw an option in the Altera megafunction setup where I can mention which ports (read address, write address, read enable, etc) should be reset when "aclr" is triggered. This also has not worked.
