Altera_ForumHonored Contributor17 years agoReserved word "bit" as signal name i don understand the coding as below: signal bit : unsigned (3 downto 0); U_Bit_counter1: Bit_counter1 port map (inc=>inc_bit, clr=>clr_bit, ...Show More
Recent DiscussionsMAX10 ADC - getting it to simulate in ModelsimFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verification
