i8087
5 years agoReproducing identical SOF when recompiling with identical source
For example in Quartus Prime Pro 20.4, can I expect to get an identical SOF everytime I recompile a design with no changes in the source?
Is there any documentation on this?
Thanks!
- 5 years ago
Having fixed seed value doesn’t mean that it will have same routing.
Having different seed value (AKA seed sweeping) is just retry compilation with different starting point. It might yield different timing result.
You may refer to timing user guide for more information ahout it:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an584.pdf
YuanLi_S_Intel
5 years agoHaving the same source code and same seed value should yield the same SOF. Unless there is a change in source code.
