FPGAOLOG
5 years agoreport levels of logic
Can you add num_logic_levels parameter to get_timing_paths command instead of get_path_info?
Current solution Intel recommends require two step filtering, storing interim results and does not nec...
SyafieqS
4 years agoLevent,
Noted on that. It would be great if there is any small toy design to indicate this issue. I can file enhancement for next Quartus release to implement parameter num_logic_levels parameter to get_timing_paths command instead of get_path_info
- FPGAOLOG4 years ago
Thank you. I noticed that Quartus already have this implemented on QPro versions. It is only missing on Q Standard.
