GD76
4 years agoRename a folder in IP catalog
In Quartus, under Tools->options->IP catalog search path ->Global IP Search
I added the a folder that has a custom IP.
When I open Platform Designer, the folder is not showing up in IP Catalog u...
sstrell
4 years agoI'm not sure why adding the IP in Quartus is preventing you from seeing it in PD, but for the folder location in the IP Catalog, that's set in the component's _hw.tcl file that got created (assuming you used the PD Component Editor to create the component). You could edit that file to change the location of the component in the IP Catalog.
