10 years agoReducing Interconnect (IC) delay with evenly distributed pipeline stages
Hi, I am getting setup violations because of large interconnect delay. I've added several pipeline stages to reduce the interconnect delay but Quartus is not doing a very good job of spreadin...
10 years agoHow to you specify timing requirements in your design? Do you constrain the desired clock rate? Do you set maximum path delays between the registers in question?
