8 years agoReal time Counter in Kernel
I want to define a real time counter and print his result . Can I define Real time clock "i" in kernel and print the result of counter?. In Other hand, I thought that I define a counter "i" in my Kernel and I store My counter "i" in global memory and then I read buffer from Host. My question : Does this counter "i" defined in kernel works under real time FPGA clock ? If yes , How I can print the result of counter ? This code (below) doesn't work for me. Kernel ( __global uint *restrict Y, int Gid = get_global_id(0); i=i+1; Y[Gid]=i; Thank you.1 Reply
There is no clock in OpenCL and there is no guarantee that your accumulation will happen once every clock. You will not be able to get clock-accurate timing results in OpenCL. However, you can get very accurate timing results (but not clock-accurate) by using OpenCL's built-in profiler:
https://stackoverflow.com/questions/23550912/measuring-execution-time-of-opencl-kernels
