11 years agoReading Data in PC from MAX10 FPGA board
Hello everyone, Greetings. I'm pretty new in FPGA area and I need a few direction in the right path to proceed with my ongoing project. I'm using MAX 10 evaluation kit and Quartus ii 15.0 web ...
11 years ago --- Quote Start --- Communication between PC and FPGA can be done via UART - just use the rs232 uart module in qsys. You will need to connect it to an avalon master like nios. Then you can write data to the uart module which will spit it out at your desired baud rate on 2 pins (UART RX and TX). You can buy a simple UART to USB converter for under $5 to interface to the USB port on the PC. What exactly are you doing with DSP builder? If you have some values you want to connect to avalon memory map from DSP builder you can use RegFields (look it up the the DSPBA manual). This will let you write values to specified address location in the memory map. You can then use NIOS to read those values and write them to UART. --- Quote End --- Thanks a lot krasner. I was actually trying to do it with on board usb blaster ii. But I guess I should try rs232. DSP builder comes with MATLAB API. I was just looking a way to communicate via MATLAB.
