skon's avatar
skon
8 years ago
Reading a file from external memory via System Console
My design captures images from an external video source and records them to DDR3.
In addition to my custom logic, I also have a Jtag to Avalog master connected the DDR3 controller (via Qsys).
Is it possible to save a section of the memory (representing a single image) into a file on my hard drive via System Console ?
  • RParks's avatar
    RParks
    I've done something similar so this might help:
    proc DDR3_read_to_file {} {
    set imagefile [open "C:/Users/RParks/system_console/scripts/image_read.mem" w]
    # set imagefile [open "/root/system_console/scripts/image_read.mem" w]
    set read_data [<ddr_read_command> <addr> <length>]
    # puts $read_data
    puts $imagefile [format "%s" $read_data]
    close $imagefile
  • RParks's avatar
    RParks
    Hi, so my solution wasn't for DDR3 and you'd need to customise it for your system but in mine I wrote a separate proc <ddr_read_command> which took 2 arguments, the address and length.
    The below might be a helpful starting point for you to write your own:
    proc memory_rd_cmd {addr length} {
    variable claimed_path
    set readdata {}
    for {set i 0} {$i < $length} {incr i} {
    lappend readdata [master_read_32 $claimed_path [expr {$addr+$i}] 1]
    return $readdata
  • skon's avatar
    skon
    Thanks for the reply.
    But where in your script do you specify the DDR3 address range that you want to be copied to the file ?
  • skon's avatar
    skon
    I'll try it.
    I thought I'd easily find an online example for this exact scenario - but I can't.
