12 years agoRead write data in max ii ufm
I have downloaded and using Quartus II v 13.1. I have also bought EPM240 core board and usb blaster programmer. I am mostly an electronic circuits person and design in circuit schematic option. ...
12 years ago --- Quote Start --- thanx . that all I have read but it is very confusing. if you can suggest some examples or codes that shows some reading and writing of data it will be of great help. also pl suggest if some videos for this are available. also how to acess that data in schematics is not clear. pl help. thanx in advance. --- Quote End --- Search for UFM on this page, and you'll see that there are example files that come with the UFM users guide. http://www.altera.com/literature/lit-ug.jsp Use Modelsim to simulate the component. As I comment above, be aware that MAX II flash can only be reprogrammed 100 times. If you're debugging using hardware, once you have downloaded the MAX II device 100 times, you're living on borrowed time. I've got a development kit I can no longer program due to this limitation. Cheers, Dave
