12 years agoRead write data in max ii ufm
I have downloaded and using Quartus II v 13.1. I have also bought EPM240 core board and usb blaster programmer. I am mostly an electronic circuits person and design in circuit schematic option. ...
12 years agoRead the MAX II handbook:
http://www.altera.com/literature/lit-max2.jsp and the MAX II UFM guide: http://www.altera.com/literature/ug/ug_alt_ufm.pdf‎ Note that the MAX II flash has 100 programming cycles (see the Programming/Erasure Specifications in the handbook). Depending on your read/write/erase requirements, you might be better off using an SPI flash or Microwire EEPROM. Cheers, Dave
