SivaKona
3 years agoRead responses on not reaching PIO interface through mm_interconnect
Quartus Version : 22.2.0.94
A "Multi Channel DMA Intel® FPGA IP for PCI Express" IP is integrated with AXI4 DUT and On Chip Memory.
Data Responses for BAR2 MMIO read requests are not reach...
Wincent_Altera
3 years agoHi,
The PIO is always mapped to BAR2, see 3.1.4. Avalon-MM PIO Master:
See also 4.1.1 which mentions the addressing:
BAR0 is always used for the Control Register Block (CSR), see 3.1.9. Control Registers
The Bursting Avalon-MM Master (BAM) can be mapped to any BAR other than 0, see 3.2. Bursting Avalon-MM Master (BAM)
8.2.7 API List, table 97 to 100 detail the PIO API format:
Our Example Design can be generate to include a PIO Master on BAR2, as a starting point you may want to generate and refer to that:
Wincent_Intel
