Elegan's avatar
Elegan
4 years ago
Timing Constraints to Active Serial Ports
Is there a possibility to put Timing Constraints (set_input_delay, set_output_delay) to the Active Serial Ports? (AS_Data, ...) Found a similar question in following post, but no solution. https:...
