hazeltet845
4 years agoRule C101 and PLL output clock
I am using Quartus II 10.1 and keep receiving the critical warning "Critical Warning: (Critical) Rule C101: Gated clock should be implemented according to the Altera standard scheme. Found 1 node(s) ...
- 4 years ago
There is a Knowledge article for this issue. Following is the link for it. Please refer.
hazeltet845
4 years agoI added the reset to the sensitivity list and am still getting the critical warning "Critical Warning: (Critical) Rule C101: Gated clock should be implemented according to the Altera standard scheme. Found 1 node(s) related to this rule". Do you know how to fix this critical warning? I think it is possibly the reason I am not meeting timing requirements.
