QuartusIQ MCP Knowledge base and docs search intermittently timing out
I tried your exact prompt, and it worked once but most other times it failed (although this now looks like a different error to before?)
I tried reloading VScode to restart the server, and the running your prompt. Here was the result
The search_altera_docs call for "FTileEthernet" failed with this exact error:
[search_altera_docs failed] fetch failed
I did not retry or answer from general knowledge, per your instructions.
To get the logs I went to "Output" tab in VS code and selected "QuartusIQ" extension, and set the log level to "trace".
2026-11-17 11:07:07.796 [info] Activating build <build-id> (<build-commit>) 2026-10-16T07:56:01Z
2026-11-17 11:07:07.796 [info] Telemetry reporter initialised
2026-11-17 11:07:07.796 [info] Trace export enabled (otel=https://<internal-otel-host>/api/public/otel environment=prod)
2026-11-17 11:07:07.796 [info] Apply handler and diff provider registered
2026-11-17 11:07:07.796 [info] Copilot compatibility probe command registered
2026-11-17 11:07:07.796 [info] [Checkpoints] LangGraph database: /home/<user>/.vscode-server/data/User/workspaceStorage/<workspace-id>/Altera.quartus-pilot-vscode/langgraph-checkpoints/checkpoints.sqlite
2026-11-17 11:07:07.796 [info] [Filesystem] Workspace root: /home/<user>/work
2026-11-17 11:07:07.796 [info] [MCP] starting child process: /home/<user>/.vscode-server/bin/<vscode-commit>/node
2026-11-17 11:07:07.796 [info] Chat participant registered
2026-11-17 11:07:08.522 [info] [MCP] {"timestamp":"2026-11-17T11:07:08.423Z","event":"programmer_start","level":"INFO","logger":"ProgrammerRuntime","tool":"server","phase":"start","msg":"server","session_id":"<session-id>","pid":<pid>,"audit_log":null,"audit_log_env":"QUARTUS_AUDIT_LOG_FILE"}
2026-11-17 11:07:17.128 [info] [MCP] {"level":30,"time":"2026-11-17T11:07:17.110Z","event":"mcp.tools.registered","changed":true,"added":["search_altera_docs","search_quartus_msgs","search_ip_knowledge_graph","search_community_docs","lookup_drc_rules","search_reference_designs","get_quartus_report_index_status","get_quartus_signoff_verdict","get_quartus_report_sections","read_quartus_report_sections","get_related_report_context","get_quartus_timing_issue_context","validate_installation","list_quartus_tools","list_device_families","create_project","get_project_info","set_assignment","run_synthesis","lint_rtl","run_fitter","run_assembler","run_timing_analysis","run_full_compile","get_job_status","cancel_job","list_jobs","get_compilation_report","ip_search","ip_lookup","vds_system","vds_build","vds_inspect","vds_hier","vds_cell","vds_connect","vds_address","vds_interconnect","vds_bsp","vds_run_tcl","analyze_bitstream","generate_programming_file","generate_helper_image","generate_rsu_jic","check_pr_compatibility","compare_files","analyze_flash_compatibility","read_jtag_config","read_config_status","program_sram_device","program_flash_device","check_qspi_flash","read_qspi_manufacturer_id"],"removed":[],"updated":[],"total":53,"inventory":{"search":["search_altera_docs","search_quartus_msgs","search_ip_knowledge_graph","search_community_docs","lookup_drc_rules","search_reference_designs"],"host":["get_quartus_report_index_status","get_quartus_signoff_verdict","get_quartus_report_sections","read_quartus_report_sections","get_related_report_context","get_quartus_timing_issue_context","validate_installation","list_quartus_tools","list_device_families","create_project","get_project_info","set_assignment","run_synthesis","lint_rtl","run_fitter","run_assembler","run_timing_analysis","run_full_compile","get_job_status","cancel_job","list_jobs","get_compilation_report","ip_search","ip_lookup","vds_system","vds_build","vds_inspect","vds_hier","vds_cell","vds_connect","vds_address","vds_interconnect","vds_bsp","vds_run_tcl","analyze_bitstream","generate_programming_file","generate_helper_image","generate_rsu_jic","check_pr_compatibility","compare_files","analyze_flash_compatibility","read_jtag_config","read_config_status","program_sram_device","program_flash_device","check_qspi_flash","read_qspi_manufacturer_id"]},"msg":"MCP tool inventory registered"}
2026-11-17 11:07:17.128 [info] [MCP] QuartusIQ MCP Server running on stdio...
2026-11-17 11:07:17.128 [info] [MCP] {"level":30,"time":"2026-11-17T11:07:17.112Z","event":"mcp.server.started","msg":"QuartusIQ MCP Server running on Stdio"}
2026-11-17 11:07:17.180 [info] [MCP] connected (pid=<pid>)
2026-11-17 11:08:05.323 [info] [chat] Progress UI: stable (chatParticipantAdditions unavailable; use Extension Development Host, VS Code Insiders, or enable-proposed-api for Altera.quartus-pilot-vscode)
2026-11-17 11:08:05.323 [info] [Model] name="Claude Haiku 5.5" id="claude-haiku-5.5" vendor="copilot" family="claude-haiku-5.5" version="claude-haiku-5.5" maxInputTokens=871793
2026-11-17 11:08:05.655 [info] [Filesystem] Approval store loaded: /home/<user>/.vscode-server/data/User/workspaceStorage/<workspace-id>/Altera.quartus-pilot-vscode/filesystem-approvals.json
2026-11-17 11:08:11.540 [info] [MCP] Resolved 53 tools: search_altera_docs, search_quartus_msgs, search_ip_knowledge_graph, search_community_docs, lookup_drc_rules, search_reference_designs, get_quartus_report_index_status, get_quartus_signoff_verdict, get_quartus_report_sections, read_quartus_report_sections, get_related_report_context, get_quartus_timing_issue_context, validate_installation, list_quartus_tools, list_device_families, create_project, get_project_info, set_assignment, run_synthesis, lint_rtl, run_fitter, run_assembler, run_timing_analysis, run_full_compile, get_job_status, cancel_job, list_jobs, get_compilation_report, ip_search, ip_lookup, vds_system, vds_build, vds_inspect, vds_hier, vds_cell, vds_connect, vds_address, vds_interconnect, vds_bsp, vds_run_tcl, analyze_bitstream, generate_programming_file, generate_helper_image, generate_rsu_jic, check_pr_compatibility, compare_files, analyze_flash_compatibility, read_jtag_config, read_config_status, program_sram_device, program_flash_device, check_qspi_flash, read_qspi_manufacturer_id
2026-11-17 11:08:11.540 [info] [HITL] Tool approval enabled for: create_project, set_assignment, run_synthesis, run_fitter, run_assembler, run_timing_analysis, run_full_compile, cancel_job, vds_system, vds_build, vds_hier, vds_cell, vds_connect, vds_address, vds_interconnect, vds_bsp, vds_run_tcl, program_sram_device, program_flash_device, check_qspi_flash, write_file, edit_file, request_external_source_access, update_approval_policy
2026-11-17 11:08:11.764 [info] [Langfuse] CallbackHandler constructed sessionId=<session-id> tags=vscode,real
2026-11-17 11:08:12.444 [debug] [stream] updates event: keys=SkillsMiddleware.before_agent
2026-11-17 11:08:12.502 [debug] [stream] updates event: keys=FilesystemMiddleware.before_agent
2026-11-17 11:08:12.575 [debug] [stream] updates event: keys=patchToolCallsMiddleware.before_agent
2026-11-17 11:08:12.580 [info] [Context] window=871793 tools=0 reserve=2048 usable=869745 trigger=652308 keep=86974
2026-11-17 11:08:14.670 [debug] [stream] updates event: keys=SummarizationMiddleware.before_model
2026-11-17 11:08:14.744 [debug] Received 2 messages from LangGraph ["[0] system: [text,text,text,text,text,text,text] (7 block(s))","[1] human: Use the search_altera_docs QuartusIQ MCP tool exactly once to search for FTileEt..."]
2026-11-17 11:08:16.172 [warning] [Tools] Description exceeds 2048 characters for: generate_rsu_jic, write_todos, task.
2026-11-17 11:08:16.172 [debug] sendRequest messages=3 tools=71 estimatedTokens=12597
2026-11-17 11:08:16.172 [debug] [Tool protocol] messages=[{"index":0,"role":"user","calls":[],"results":[]},{"index":1,"role":"assistant","calls":[],"results":[]},{"index":2,"role":"user","calls":[],"results":[]}] adjacencyViolations=[]
2026-11-17 11:08:30.722 [debug] ToolCallPart callId=<tool-call-id> name=search_altera_docs
2026-11-17 11:08:30.722 [debug] LanguageModelDataPart skipped (non-text mime): usage
2026-11-17 11:08:30.767 [debug] Stream complete. toolCallParts=1
2026-11-17 11:08:30.775 [debug] [stream] msgType=ai isSubagent=false ns=["model_request:<request-id>"]
2026-11-17 11:08:30.852 [debug] [stream] updates event: keys=model_request
2026-11-17 11:08:30.906 [debug] [stream] updates event: keys=HumanInTheLoopMiddleware.after_model
2026-11-17 11:08:30.988 [debug] [stream] updates event: keys=todoListMiddleware.after_model
2026-11-17 11:08:44.080 [info] [MCP] {"level":50,"time":"2026-11-17T11:08:43.859Z","err":{"type":"Error","message":"fetch failed: fetch failed: ","stack":"Error: fetch failed\n at /home/<user>/.vscode-server/extensions/altera.quartus-pilot-vscode-0.10.8/mcpServer.cjs:7:666032\n at processTicksAndRejections (node:internal/process/task_queues:104:5)\n at runNextTicks (node:internal/process/task_queues:69:3)\n at process.processTimers (node:internal/timers:615:9)\n at async _0x2e5531.execute (/home/<user>/.vscode-server/extensions/altera.quartus-pilot-vscode-0.10.8/mcpServer.cjs:7:673195)\n at async _0x51fd6b (/home/<user>/.vscode-server/extensions/altera.quartus-pilot-vscode-0.10.8/mcpServer.cjs:7:659421)\n at async /home/<user>/.vscode-server/extensions/altera.quartus-pilot-vscode-0.10.8/mcpServer.cjs:7:641025\n at async _0x30123a.executeToolHandler (/home/<user>/.vscode-server/extensions/altera.quartus-pilot-vscode-0.10.8/mcpServer.cjs:7:87693)\n at async /home/<user>/.vscode-server/extensions/altera.quartus-pilot-vscode-0.10.8/mcpServer.cjs:7:84988\n at async _0x30ecce (/home/<user>/.vscode-server/extensions/altera.quartus-pilot-vscode-0.10.8/mcpServer.cjs:7:59993)\ncaused by: TypeError: fetch failed\ncaused by: AggregateError [ETIMEDOUT]: \n at internalConnectMultiple (node:net:1492:18)\n at internalConnectMultiple (node:net:1568:5)\n at Timeout.internalConnectMultipleTimeout (node:net:2188:5)\n at listOnTimeout (node:internal/timers:687:11)\n at process.processTimers (node:internal/timers:618:7)"},"tool":"search_altera_docs","msg":"MCP tool execution failed: fetch failed"}
2026-11-17 11:08:44.156 [debug] [stream] updates event: keys=tools
2026-11-17 11:08:44.161 [info] [Context] window=871793 tools=27941 reserve=2048 usable=841804 trigger=631353 keep=84180
2026-11-17 11:08:44.162 [debug] [stream] msgType=tool isSubagent=true ns=["tools:<namespace-id>"]
2026-11-17 11:08:45.609 [debug] [stream] updates event: keys=SummarizationMiddleware.before_model
2026-11-17 11:08:45.643 [debug] Received 4 messages from LangGraph ["[0] system: [text,text,text,text,text,text,text] (7 block(s))","[1] human: Use the search_altera_docs QuartusIQ MCP tool exactly once to search for FTileEt...","[2] ai: ...","[3] tool: [search_altera_docs failed] fetch failed..."]
2026-11-17 11:08:45.650 [warning] [Tools] Description exceeds 2048 characters for: generate_rsu_jic, write_todos, task.
2026-11-17 11:08:45.650 [debug] sendRequest messages=5 tools=71 estimatedTokens=12740
2026-11-17 11:08:45.650 [debug] [Tool protocol] messages=[{"index":0,"role":"user","calls":[],"results":[]},{"index":1,"role":"assistant","calls":[],"results":[]},{"index":2,"role":"user","calls":[],"results":[]},{"index":3,"role":"assistant","calls":[{"id":"<tool-call-id>","name":"search_altera_docs"}],"results":[]},{"index":4,"role":"user","calls":[],"results":["<tool-call-id>"]}] adjacencyViolations=[]
2026-11-17 11:08:47.105 [debug] LanguageModelDataPart skipped (non-text mime): usage
2026-11-17 11:08:47.117 [debug] Stream complete. toolCallParts=0
2026-11-17 11:08:47.122 [debug] [stream] msgType=ai isSubagent=false ns=["model_request:<request-id>"]
2026-11-17 11:08:47.122 [debug] [stream] text (main): The `search_altera_docs` call for "FTileEthernet" failed once with this exact er...
2026-11-17 11:08:47.122 [debug] [stream] Main agent outputting: The `search_altera_docs` call for "FTileEthernet" ...
2026-11-17 11:08:47.177 [debug] [stream] updates event: keys=model_request
2026-11-17 11:08:47.243 [debug] [stream] updates event: keys=HumanInTheLoopMiddleware.after_model
2026-11-17 11:08:47.282 [debug] [stream] updates event: keys=todoListMiddleware.after_model
2026-11-17 11:08:47.298 [info] [stream] Complete. main agent chunks: 1, subagent chunks: 0It looks like you are sending telemetry so maybe you can debug it that way!
I tried other search tools and they failed similarly
@QuartusIQ Use the following MCP tools exactly once to search for FTileEthernet. Do not retry, call another search tool, or answer from general knowledge if the tool fails. Return the tool result or the exact error message.
search_altera_docs
Result:
The search for FTileEthernet returned errors from all four tools. I did not retry or answer from general knowledge.
Tool Result search_altera_docs [search_altera_docs failed] fetch failed search_ip_knowledge_graph [search_ip_knowledge_graph failed] fetch failed search_community_docs [search_community_docs failed] fetch failed search_reference_designs [search_reference_designs failed] Reference design catalog fetch timed out after 10000ms
2026-11-17 10:43:42.208 [info] [Context] window=871793 tools=0 reserve=2048 usable=869745 trigger=652308 keep=86974
2026-11-17 10:43:43.207 [warning] [Tools] Description exceeds 2048 characters for: generate_rsu_jic, write_todos, task.
2026-11-17 10:44:41.804 [info] [MCP] {"level":50,"time":"2026-11-17T10:44:40.746Z","err":{"type":"Error","message":"fetch failed: fetch failed: ","stack":"Error: fetch failed\n at /home/<user>/.vscode-server/extensions/altera.quartus-pilot-vscode-0.10.8/mcpServer.cjs:7:666032\n at processTicksAndRejections (node:internal/process/task_queues:104:5)\n at runNextTicks (node:internal/process/task_queues:69:3)\n at listOnTimeout (node:internal/timers:644:9)\n at process.processTimers (node:internal/timers:618:7)\n at async _0x2e5531.execute (/home/<user>/.vscode-server/extensions/altera.quartus-pilot-vscode-0.10.8/mcpServer.cjs:7:673195)\n at async _0x51fd6b (/home/<user>/.vscode-server/extensions/altera.quartus-pilot-vscode-0.10.8/mcpServer.cjs:7:659421)\n at async /home/<user>/.vscode-server/extensions/altera.quartus-pilot-vscode-0.10.8/mcpServer.cjs:7:641025\n at async _0x30123a.executeToolHandler (/home/<user>/.vscode-server/extensions/altera.quartus-pilot-vscode-0.10.8/mcpServer.cjs:7:87693)\n at async /home/<user>/.vscode-server/extensions/altera.quartus-pilot-vscode-0.10.8/mcpServer.cjs:7:84988\ncaused by: TypeError: fetch failed\ncaused by: AggregateError [ETIMEDOUT]: \n at internalConnectMultiple (node:net:1492:18)\n at internalConnectMultiple (node:net:1568:5)\n at Timeout.internalConnectMultipleTimeout (node:net:2188:5)\n at listOnTimeout (node:internal/timers:687:11)\n at process.processTimers (node:internal/timers:618:7)"},"tool":"search_altera_docs","msg":"MCP tool execution failed: fetch failed"}
2026-11-17 10:44:41.804 [info] [MCP] {"level":50,"time":"2026-11-17T10:44:40.747Z","err":{"type":"Error","message":"fetch failed: fetch failed: ","stack":"Error: fetch failed\n at /home/<user>/.vscode-server/extensions/altera.quartus-pilot-vscode-0.10.8/mcpServer.cjs:7:666032\n at processTicksAndRejections (node:internal/process/task_queues:104:5)\n at runNextTicks (node:internal/process/task_queues:69:3)\n at listOnTimeout (node:internal/timers:644:9)\n at process.processTimers (node:internal/timers:618:7)\n at async _0x319427.execute (/home/<user>/.vscode-server/extensions/altera.quartus-pilot-vscode-0.10.8/mcpServer.cjs:7:764634)\n at async _0x51fd6b (/home/<user>/.vscode-server/extensions/altera.quartus-pilot-vscode-0.10.8/mcpServer.cjs:7:659421)\n at async /home/<user>/.vscode-server/extensions/altera.quartus-pilot-vscode-0.10.8/mcpServer.cjs:7:641025\n at async _0x30123a.executeToolHandler (/home/<user>/.vscode-server/extensions/altera.quartus-pilot-vscode-0.10.8/mcpServer.cjs:7:87693)\n at async /home/<user>/.vscode-server/extensions/altera.quartus-pilot-vscode-0.10.8/mcpServer.cjs:7:84988\ncaused by: TypeError: fetch failed\ncaused by: AggregateError [ETIMEDOUT]: \n at internalConnectMultiple (node:net:1492:18)\n at internalConnectMultiple (node:net:1568:5)\n at Timeout.internalConnectMultipleTimeout (node:net:2188:5)\n at listOnTimeout (node:internal/timers:687:11)\n at process.processTimers (node:internal/timers:618:7)"},"tool":"search_ip_knowledge_graph","msg":"MCP tool execution failed: fetch failed"}
2026-11-17 10:44:41.804 [info] [MCP] {"level":50,"time":"2026-11-17T10:44:40.748Z","err":{"type":"Error","message":"fetch failed: fetch failed: ","stack":"Error: fetch failed\n at /home/<user>/.vscode-server/extensions/altera.quartus-pilot-vscode-0.10.8/mcpServer.cjs:7:666032\n at processTicksAndRejections (node:internal/process/task_queues:104:5)\n at runNextTicks (node:internal/process/task_queues:69:3)\n at process.processTimers (node:internal/timers:615:9)\n at async _0x38f046.execute (/home/<user>/.vscode-server/extensions/altera.quartus-pilot-vscode-0.10.8/mcpServer.cjs:7:676298)\n at async _0x51fd6b (/home/<user>/.vscode-server/extensions/altera.quartus-pilot-vscode-0.10.8/mcpServer.cjs:7:659421)\n at async /home/<user>/.vscode-server/extensions/altera.quartus-pilot-vscode-0.10.8/mcpServer.cjs:7:641025\n at async _0x30123a.executeToolHandler (/home/<user>/.vscode-server/extensions/altera.quartus-pilot-vscode-0.10.8/mcpServer.cjs:7:87693)\n at async /home/<user>/.vscode-server/extensions/altera.quartus-pilot-vscode-0.10.8/mcpServer.cjs:7:84988\n at async _0x30ecce (/home/<user>/.vscode-server/extensions/altera.quartus-pilot-vscode-0.10.8/mcpServer.cjs:7:59993)\ncaused by: TypeError: fetch failed\ncaused by: AggregateError [ETIMEDOUT]: \n at internalConnectMultiple (node:net:1492:18)\n at internalConnectMultiple (node:net:1568:5)\n at Timeout.internalConnectMultipleTimeout (node:net:2188:5)\n at listOnTimeout (node:internal/timers:687:11)\n at process.processTimers (node:internal/timers:618:7)"},"tool":"search_community_docs","msg":"MCP tool execution failed: fetch failed"}If I try the prompt: @QuartusIQ Use the search_ip_knowledge_graph QuartusIQ MCP tool exactly once to search for FTileEthernet. Do not retry, call another search tool, or answer from general knowledge if the tool fails. Return the tool result or the exact error message.
Complete
search_ip_knowledge_graph returned 10 results for FTileEthernet, with no filters applied.
Result
Type
Device families returned
1
F-Tile Ethernet Hard IP (10G–400G, RS-FEC, FC FEC, IEEE 1588) [1][2][3]
HardIP
Agilex 7, Agilex 9
2
F-Tile Ethernet Hard IP [1]
HardIP
Agilex 7, Agilex 9
3
F-Tile 25G Ethernet IP [4]
HardIP
Agilex 7, Agilex 9
4
F-Tile Low Latency 50G Ethernet IP User Guide (Agilex 7 F-Tile + Agilex 9 F-Tile) [5]
Document
5
F-Tile Ethernet Multirate IP [6]
HardIP
Agilex 7, Agilex 9
6
F-Tile Low Latency 50G Ethernet IP [5]
HardIP
Agilex 7, Agilex 9
7
F-Tile Ethernet Hard IP Design Example User Guide (UG-20326) [2]
Document
8
Ethernet Subsystem IP (F-Tile multi-port, 40GbE XAUI-4 + up to 400G core) [7]
HardIP
Agilex 7, Agilex 9
9
HardIP
Agilex 7
10
F-Tile Ethernet Hard IP User Guide (UG-20313) [1]
Document
References
[1] F-Tile Ethernet Hard IP User Guide
[2] F-Tile Ethernet Hard IP Design Example User Guide
[3] F-Tile Architecture and PMA and FEC Direct PHY Design Implementation Guide
[4] F-Tile 25G Ethernet IP User Guide
[5] F-Tile Low Latency 50G Ethernet IP User Guide
[6] F-Tile Ethernet Multirate IP User Guide
[7] Ethernet Subsystem IP User Guide (F-Tile)
The search is quite fast without problem.
