PixelPusher
11 days agoQuartusIQ MCP Knowledge base and docs search intermittently timing out
Hi, I have started trying out the QuartusIQ MCP in VS code to search through knowledge base and docs faster using an AI model. I have noticed that the docs and knowledge search times out around 60% o...
KennyT_altera
10 days agoCan you provide me the prompt that you use the duplicate the issue in VScode? Also the prompt to generate the MCP logs files. I try to use the prompt below but seems like got error:
@QuartusIQ Use the search_altera_docs QuartusIQ MCP tool exactly once to search for FTileEthernet. Do not retry, call another search tool, or answer from general knowledge if the tool fails. Return the tool result or the exact error message.
