ModelSim Wave Image Export Error - image file format "bmp" is unknown
Hi Pietro4,
May I know what do you meant by "I can't even print a readable file."? Is the issue related to Modelsim? Could you help to describe more on this? Appreciate if you could share the screenshot.
Richard
Hi ,
I managed to solve the problems regarding the printing of files.
I still have problem to export an image from wave, the same as @NH_Dal.
Thanks for the help.
Pietro
- RichardT_altera5 years ago
I am still pending for engineering to investigate on this.
It seems to work in Linux OS, could you try in Linux and verify whether the image export works?Best Regards,
Richard Tan
