ModelSim Wave Image Export Error - image file format "bmp" is unknown
That's weird...I also get the same thing.
Let's me check with the engineering team on this.
For now, please use snipping tool or screenshot as a workaround.
Me and my mates have the same problem, I can't even print a readable file.
The only way is to print a pdf file but that's not what I need.
- RichardT_altera5 years ago
Hi Pietro4,
May I know what do you meant by "I can't even print a readable file."? Is the issue related to Modelsim? Could you help to describe more on this? Appreciate if you could share the screenshot.
Richard
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.- Pietro45 years ago
Hi ,
I managed to solve the problems regarding the printing of files.
I still have problem to export an image from wave, the same as @NH_Dal.Thanks for the help.
Pietro
I am still pending for engineering to investigate on this.
It seems to work in Linux OS, could you try in Linux and verify whether the image export works?Best Regards,
Richard Tan
