ModelSim*-Intel® FPGA Edition Software - Simulation Error
What IP do you have in your design? Sounds like you're missing a license or something.
I am trying to simulate some part of the project s10_ref BSP for some openCL application. The project is in platform designer format so to simulate the project I have generated the vhdl codes of the ip files in the platform designer. The project contains two ddr4 memory. When I try to simulate the project modelsim says fourteennm_iossm module (which is instantiated in a file generated automatically by platform designer for ddr4 memory) not found. So I searched the quartus installition directory and find that module in the library folder containing altera starter edition library files (the location of the file is "Local Disk (C:) / intelFPGA_pro / 20.4 / modelsim_ase / altera / verilog / src / fourteennm_atoms.sv" ).This file is fourteennm_atoms.sv. However, when I do that modelsim now says fourteen_iossm_mchip_encrypted module cannot be found which is instatiated in fourteennm_iossm module contained in fourteennm_atoms.vs.
Note: When I add project files to modelsim and compile them, all of them are compiled successfully. However, when I click on the Start Simulation it says instantiation of fourteennm_iossm failed.
I haven't add anything special to the project. I have used the same structure as you did in s10_ref BSP project, but I have taken some part of the project which I do not need to simulate.
I have tried to tell all of the story in detail.
Thanks for your reply.
