NKamm
8 years agoRe link .sopcinfo file to the project after copying
Hi, I have copied the entire quartus project from one location to the other in the same pc. But in eclipse the bsp is linked with the previous location sopc file. How can i re link the .sopc to the...
Abe
8 years agoYou could open your BSP project that you copied over in Eclipse , right-click the BSP and choose BSP Editor.
In the window that pops up, from the File menu select Open and then select the settings.bsp file that you would like to use. This should be from the one you copied over.
The BSP editor will change the paths relative to the settings file chosen. Close the Editor, Build the project and check.
