beiwang2003
5 years agoinstall oneAPI on RHEL OS with D5050 card
We have a D5050 card with Springdale Linux 7.9, a custom red-hat based distribution. We then follow the instruction here to install the required packages for oneAPI. However, we had the following err...
BoonBengT_Altera
Moderator
5 years agoHi @beiwang2003,
Just following up on the issues, by any chances did you managed to look into the previous suggestion to see if it helps?
Hope to hear from you soon.
Best Wishes
BB
beiwang2003
5 years agoHi, BB,
Yes, -gcc-toolchain was specified in the compiling process, but it didn't seem to work. We figured out that oneAPI add-on was not properly installed. We are now working on a fresh installation and will keep you posted for the result.
Thanks for the follow up.
Bei
