ibis_writer.py "Execution has failed. Reason is: Parasitic file not found."
- 3 years ago
Based on the user guide https://www.intel.com/content/www/us/en/docs/programmable/683768/23-1/ibis-model-access-and-customization-flows.html, it mentioned that the generation of IBIS model for Agilex 7 is not supported. You need to install/download the IBIS models provided in https://www.intel.com/content/www/us/en/support/programmable/support-resources/board-layout/ibs-ibis-index.html.
Aqid
Followed the instructions in $QUARTUS_INSTALL_DIR/common/misc/ibis_writer/README.txt
quartus_cdb -t /<absolute_path>/intel_type3_cxl_ip_0_ed/hardware_test_design/ibis/dump_atom_netlist.tcl -project /<absolute_path>/intel_type3_cxl_ip_0_ed/hardware_test_design/cxltyp3_memexp_ddr4_top.qpf
$QUARTUS_INSTALL_DIR/common/misc/ibis_writer/ibis_writer.py --mutual_inductance true --pin_file /<absolute_path>/intel_type3_cxl_ip_0_ed/hardware_test_design/output_files/cxltyp3_memexp_ddr4_top.pin --atom_file /<absolute_path>/intel_type3_cxl_ip_0_ed/hardware_test_design/atom_netlist.json /<absolute_path>/intel_type3_cxl_ip_0_ed/hardware_test_design/output_files/cxltyp3_memexp_ddr4_top.ibs
Device is: AGIB027R29A1E2VR3
