FIR II Decimation Frequency Response
Thanks for your help. Sorry for the inconvenience. I still get into the following error:
Error using .*
Matrix dimensions must agree.
Error in fir_inspect (line 5)
sinevector=(2^(inBits-1)-1)*sin(2*pi*clock.*freqsMhz'/smpRateMhz);
It seems like the clock dimension mismatches with freqsMhz. Also, I have tested manually change the clock to 1x65, it will prompt another error on " '/ " operator. I changed to " ./ " the file can run but the simulation output is a waveform like plot which I believe due to incorrect changes from my side.
Note that I have not run the Modelsim but just testing on the .m file since there is a decim_fir_output.txt available in your folder.
Thanks for your patience. I've never had so much trouble with matlab compatibility... Please try the attached.
