sorry for the late reply, caught on some other work.
actually i didnt tried installing on other PC. but I tried to install the quartus prime lite version.
and while running the simulation library compiler it shows as follows
Info: Command: quartus_sh --simlib_comp -tool modelsim -language vhdl -tool_path C:/intelFPGA_lite/20.1/modelsim_ae/win32aloem/ -directory C:/Users/murali.kumar/Desktop/OLD_SIM/learn/prime_lite -rtl_only
Info: Quartus(args): -tool modelsim -language vhdl -tool_path C:/intelFPGA_lite/20.1/modelsim_ae/win32aloem/ -directory C:/Users/murali.kumar/Desktop/OLD_SIM/learn/prime_lite -rtl_only
Info: Changing the current directory to output directory C:/Users/murali.kumar/Desktop/OLD_SIM/learn/prime_lite ..
Info: Using Path C:/intelFPGA_lite/20.1/modelsim_ae/win32aloem/ that was set in EDA Simulation Library Compiler Options
Info: Generating commands to compile library altera ...
Info: Generating commands to compile library lpm ...
Info: Generating commands to compile library sgate ...
Info: Generating commands to compile library altera_mf ...
Info: Generating commands to compile library altera_lnsim ...
Info: Executing command file containing library compilation commands
Info: Unable to checkout a license. Vsim is closing.
Error: ** Error: Invalid license environment. Application closing.
Info: Unable to checkout a license. Make sure your license file environment variables are set correctly and then run 'lmutil lmdiag' to diagnose the problem.
Info: Modelsim - Intel FPGA Edition uses the following environment variables to check the licenses (listed in the order of preference)
Info: 1. MGLS_LICENSE_FILE
Info: 2. LM_LICENSE_FILE.
Error: Compilation was NOT successful. 1 errors, 0 warnings
Kindly do the needful
MuralikumarM
