8 years agorbf to pof conversion
Is there a way to convert a rbf file to a pof file? Do I need a cof file? If so, how to I generate it? All I have is the released version of my rbf. I do have a project which has an earlier ver...
8 years agoThe RBF file is used to program the Altera EPROM, which then programs the FPGA using Active Serial. The EPROM can also be accessed through USB Blaster and programmed witha POF File. The FPGA can be accessed via the JTAG inputs and programmed with a SOF file.
Is it possible to use the programmer to read back either the EPROM and savr it as a POF or the FPGA and save it as a SOF?
