8 years agorbf to pof conversion
Is there a way to convert a rbf file to a pof file? Do I need a cof file? If so, how to I generate it? All I have is the released version of my rbf. I do have a project which has an earlier ver...
8 years agoHi,
Do you also have the .sof file ? With the sof file you can generate the pof file from the 'Convert Programming File' tool: File->Convert Programming File or quartus_cpf in command line. You can generate the cof file from the UI of this tool. If you only have the rbf file... I don't know... Regards
