16 years agoRapid recompile
Anybody tried the rapid recompile feature in Quartus 9.1? With rapid recompile feature switched on: I took a unpartioned flat design on an 80% full EP4SGX230 Stratix device and ran it through...
16 years ago --- Quote Start --- No its not smart recomple or partitioning it's the new feature on Quartus 9.1. http://www.altera.com/products/software/quartus-ii/whats-new/swf-qts-whats-new.html?gsa_pos=2&wt.oss_r=1&wt.oss=rapid%20recompile I set it using...
set_global_assignment -name RAPID_RECOMPILE_MODE
COMPATIBLE_PLACEMENTI've found it to be of little use, unless I'm doing something wrong. --- Quote End --- Hi Witty, I was not aware of this new feature, but I can imagine how it works. The feature could only work in case that Quartus found a lot of nodes which does not change. I'm pretty sure that changing the input value of the reset will cause a lot of changes in your FPGA implementation. I would try a change which influenced only a small portion of your design (e.g reduce the number of bits of a counter) Kind regards GPK
