15 years agoIn Quartus, from the Assignments menu, select "Design Partitions Window". Then from the Project Navigator window find all instances of your RAM and either right click to create a partition around it or click and drag it to the Design Partitions Window. If the code infers into memory when compiled at the top level, then I am pretty sure this will do the trick.
