15 years agoHello again,
In my original code (the code that failed) the uninferred RAM data output was connected straight to the address input of a different RAM block. Can this be the source of the trouble? The problem disappeared when I inserted a layer of logic between data output and address input. This is the only difference I can think of between this and many other designs in which I used this inferred RAM construct witl Quartus-2. I don't remember seeing this case mentioned in the manual but I'll have to check again more carefully... I will conduct an experiment and post the result ASAP.
