15 years agoI am trying to install Quartus 2 10.1 on Kubuntu... a nightmare on its own right. I wonder if the guys at Altera have ever heard of apt-get or Ubuntu... When and if I get the install done I will try my code on it.
As for the partition, I have first to figure what a 'partition' is in this context :) thanks for the tip. The manual warns you that RAM inference can fail of the RAM output goes straight to a hierarchy boundary (which it does). But I have used this exact same construct in the past with no trouble, and as I said, when you compile the cache module separately (i.e. not connected to a parent module) it works fine. I will try moving the RAM to a separate module and see if it helps...
