13 years agoRam and Rom
I have this Wrong Messages.:confused:
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity BUS_VHDL is port ( CS_ROM_n : out std_logic; CS_OUT_LED_n : out std_logic; bus_en_n : in std_logic; <<wrong---- Error (12014): Net "gdfx_temp0", which fans out to "BUS_VHDL:inst4|bus_en_n", cannot be assigned more than one value ---- Addr_bus : in std_logic_vector(7 downto 0) ); End entity; architecture rtl of BUS_VHDL is Begin process(Addr_bus, bus_en_n) begin if bus_en_n = '0' then if unsigned(addr_bus) > 0 AND unsigned(addr_bus) < 16 then -- ROM adress CS_ROM_n <= '0'; else CS_ROM_n <= '1'; end if; if addr_bus = "00010000" then -- OUT_LED adress CS_OUT_LED_n <= '0'; else CS_OUT_LED_n <= '1'; end if; else CS_ROM_n <= '1'; CS_OUT_LED_n <= '1'; end if; end process; end rtl;
