15 years agoThe problem is, your code doesnt really follow a template quartus can recognise as a real bit of hardware. What you're asking it to do is put '1' on the "Ld_firstbyte" signal only when the clock rises, and then drop back to '0' when the clock is stable again. This is not a register or any real logic. Some fixes:
1. You need rst in the sensitivity list, else reigsters wont reset in simulation unless there is a clock. 2. Remove MULT_CLK from the sensitivity list. 3. Put the MULT clk inside the intRCLK clk tree. What you want is this:
Loader_start_state : process (rst, intRCLK)
begin
if (rst = '1') then
Ld_firstbyte <= '0';
elsif ((intRCLK'EVENT) and (intRCLK = '1') then --why not use the rising_edge function isntead?
if(MULT_CLK='1')) then
Ld_firstbyte <= '1';
else
end if;
end if;
end process Loader_start_state;
As an asside - using clocks directly for logic is usually a BAD THING.
