15 years agoThere is no such thing as a register that is clocked off two edges. I'm not sure what you're trying to do, as no edges occur at the same time(as the resolution gets smaller, at some point they will be different). You can either do something combinatorially with the clocks(like AND them), or have registers based off each one independently and do the logic after that.
