questions when upgrade to Quartus Pro
- 4 years ago
Hi Sun,
I believe delete and re-add the IP is the best way to try and not complicated as you thought (drag and connect). Make sure you have a back up qar before make any changes. My suggestion if you are not sure what parameter, open the original design in STD, mark what parameters necessary and add them in new added IP in PRO. Then generate and compile. This should be able to fix your issue.
Hi Sun,
Hi SyafieqS,
I accepted your post as solution, that is from the strategy level, now when I start the operation. the first problem I have is shown in the following screen capture.
jest_top_qsys_0 here is a submodule of jest204b, from parameter you can see the LMF is 16, 4, 2. when I create a new jest_top. the Maximum L value is 8. the problem is that I couldn't find the jest_top_qsys_0.qsys in the project. from the detail screen capture, the author is unknown, and all description are none. I hope I can have a little bit more detail besides the strategy in this special case.
there is only one sub-directory called synth in directory
C:\FPGA_std18\TSWJ57\Orig\ip\jesd204b\jesd_top_qsys_10
almost all files in synth are .sv file.
seems I need re-generate a new .qys called jesd_top_qsys_10, but I lost the track of this module, even the project compile successfully.
Appreciate your help.
David
