questions when upgrade to Quartus Pro
- 4 years ago
Hi Sun,
I believe delete and re-add the IP is the best way to try and not complicated as you thought (drag and connect). Make sure you have a back up qar before make any changes. My suggestion if you are not sure what parameter, open the original design in STD, mark what parameters necessary and add them in new added IP in PRO. Then generate and compile. This should be able to fix your issue.
You probably need to delete and re-add the IP in your Platform Designer system. The tool may not have been able to update the old version.
- dsun014 years ago
Contributor
Hi Sstrell,
Thank you for the reply, I am new to this platform designer, still not that confident to replace the IPs. but if it is the right way to fix the problem, I will give it a try. appreciate your help.
David
- dsun014 years ago
Contributor
Hi Sstrell
I had a look regenerating the IPs, it is much more complicate than I thought, it seems to me like redesign everything, here is why. if I understand correctly, in the following picture, the blue color highlighted line is the IP, it is just a wrapper layer. you can see all the parameters are exactly same to the module under it, which is a .SV file. I am still working on the timing understanding and fixing. I just want to know does my understanding here make any sense.
thank you for your help.
David
