dsun01
Contributor
4 years agoquestions when upgrade to Quartus Pro
Dear Support and Expert,
I have a project from TI, it is a Jesd204B design. the original design was in old Quartus standard edition. may be 16 or 17, first I updated to 18.1. everything seems worki...
- 4 years ago
Hi Sun,
I believe delete and re-add the IP is the best way to try and not complicated as you thought (drag and connect). Make sure you have a back up qar before make any changes. My suggestion if you are not sure what parameter, open the original design in STD, mark what parameters necessary and add them in new added IP in PRO. Then generate and compile. This should be able to fix your issue.
dsun01
Contributor
4 years agohere is the image of the compilation complete image
