Altera_ForumHonored Contributor11 years agoQuestions about fft megafucntion Hello dears, I'll use altera's fft megafunction, and there are several question need you help: 1. The input data coming from ADC's sampling values, the sample speed is 25Mhz. However, my syst...Show More
Recent DiscussionsMAX10 ADC - getting it to simulate in ModelsimFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verification
