Altera_ForumHonored Contributor12 years agoQuestions about clock group in timing constrain I have a question about clock group. Assume in a design, there are two clocks: clk1 and clk2. They are outputs of a PLL. There are no data paths between clk1 and clk2, that means no signals...Show More
Altera_ForumHonored Contributor12 years agoThanks very much, Rysc. If I have other related questions later, I will post here.
Recent DiscussionsInterfacing Avalon Streaming FIFO IP with GTS Ethernet Hard IPInvalid license key (inconsistent authentication code)Regarding the issue of UFM not startingram retimingReset Release IP for Agilex needs Stratix 10 device files installed!
