13 years ago --- Quote Start --- I will try to use ALTPLL_RECONFIG and let you know the results. --- Quote End --- Before you do that, check whether you are actually getting data using SignalTap II. You can then look at see whether the data is being received incorrectly, or perhaps gain some insight as to your problem. Cheers, Dave
