Altera_ForumHonored Contributor13 years agoQuestion regarding to PLL of Cyclone IV There is a 40MHZ master clock in my system and I am using this master clock to generate a 160MHZ to capture the incoming data. The problem is sometimes I can capture the right data but sometime...Show More
Altera_ForumHonored Contributor13 years agoHi Dave, I will try to use ALTPLL_RECONFIG and let you know the results. Many thanks. David.
Recent DiscussionsSSLC Login Issue – "You need to enroll" loop after OTP verificationflexlm errorQuesta Sim on Windows - linking to external LIBSolvedFree Licence for Max+PlusIIQuartus crashes on long carry chain in Agilex 5 FPGAs
