8 years agoQUESTION on Signal Assignment of same signal and measuring times in FPGA.
Dear all, can you tell me if the following is an illegal statement in VHDL 2008. I want to count up a signal read_pointer synchronously but I am not sure if the signal assignment of the same signa...
8 years agoYes - use a counter to measure time, in clock cycles. That's how I would do it.
As for your code - fundamentally it's about right. What signal type are you proposing for 'read_pointer'? Depending on what that is will determine whether you need single quotes around the '1'. I'd suggest using an 'unsigned' type or an integer with a positive range. Then you wouldn't put single quotes around your + 1. Whether you need a 'buffer' signal depends whether 'read_pointer' in a output port to your entity. You can't read output ports. So, if so, you'd need a local buffer which you'd increment and also assign to the relevant output port. Cheers, Alex
