10 years agoQuestion about unconstrained input/ouput paths
Let's say I do not specify any input/output constraints in my design (set_input_delay/set_output_delay). This means there is nothing to report 'to the input register' as well as 'from the output regi...
10 years ago --- Quote Start --- Kaz, do you mind elaborating more on this part as I am not familiar how I/O timing works with regards to tSU/tH/tCO. Does that mean fitter will randomly assign some values for those if unconstrained? --- Quote End --- yes it will as it inserts delays freely. If it was me I will issue warning (or error) and stop compilation. However some designers prefer to close timing in three stages: 1) do internal paths only 2) add io 3) adding exceptions the easiest is first and must pass before moving on. I personally put it all in one go. The tSU/tH achieved at inputs and tCO at outputs will be reported under device datasheet.
