11 years agoQuestion about sync/async reset and recovery/removal
I understand most of the recommendation when implementing reset scheme is using asynchronous assertion and synchronous deassertion. My question is why do we need sync deassertion given that it is alr...
11 years ago --- Quote Start --- I understand this part, but again it is resetting the asynchronous part of the registers. Will this be analyzed as setup/hold or recovery/removal. If the latter, shouldn't it be considered asynchronous? My understanding is synchronous reset should be going through the D input of the registers. Thanks. --- Quote End --- The Q2 output can be connected either to the async register port(Altera recommends and saves resource) or applied through D input(Xilinx prefers, wastes resource). In either case the reset signal must be presynchronised to help achieve recovery/removal if applied async or setup/hold if applied through D input.
