11 years agoQuestion about sync/async reset and recovery/removal
I understand most of the recommendation when implementing reset scheme is using asynchronous assertion and synchronous deassertion. My question is why do we need sync deassertion given that it is alr...
11 years ago --- Quote Start --- Q2 is then used as reset for the system registers. --- Quote End --- I understand this part, but again it is resetting the asynchronous part of the registers. Will this be analyzed as setup/hold or recovery/removal. If the latter, shouldn't it be considered asynchronous? My understanding is synchronous reset should be going through the D input of the registers. Thanks.
