11 years agoQuestion about sync/async reset and recovery/removal
I understand most of the recommendation when implementing reset scheme is using asynchronous assertion and synchronous deassertion. My question is why do we need sync deassertion given that it is alr...
11 years ago --- Quote Start --- I understand most of the recommendation when implementing reset scheme is using asynchronous assertion and synchronous deassertion. My question is why do we need sync deassertion given that it is already analyzed using recovery/removal. --- Quote End --- Altera(not everbody) recommends that and is meant to help achieve recovery/removal timing requirements so the two are not alternatives. --- Quote Start --- Also, I am still confused how is the output of the double synchronizer considered synchronous as they are still feeding the aclr port of the Flip-Flops and will still be analyzed under recovery/removal instead of setup/hold. --- Quote End --- Which double synchroniser you refer to?
