Altera_ForumHonored Contributor18 years agoquestion about set_input_delay The following list describes the options for the set_input_delay command, anybody tell me when shall we specify the -rise|-fall option? -clock <clock name> Specifies the source clock. -clock...Show More
Recent DiscussionsMAX10 ADC - getting it to simulate in ModelsimFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verification
