12 years ago --- Quote Start --- The only options I know of are: 1. Use a bigger device. 2. Modify your algorithm. Are you sure you havent accidently set the limits of the DSP blocks to fewer than the device has, having played with the settings. --- Quote End --- I use the default setting. Then why just the Compilation use other Hardware instead of the DSP when the DSP resource cant fit the design?
