12 years agoI think the multipliers are generated by the megawizard cause I used a lot of Arithmetic IP in megawizard such as ALTFP_DIV, ALTFP_EXP and so on.
As I mentioned in another thread(which is replied by you.Thanks again Tricky), I just want to compare two Algorithm's hardware consumption. Because one of them,when I do compilation, does not consume DSP block, while the other one does. Then I think is there any method to ban the DSP block when compilation,only to use the register and LUT.
