12 years ago --- Quote Start --- You also might want to set "maximum DSP block usage" to 0. --- Quote End --- Thanks Tricky, I followed your step turning the "Auto DSP Block Replacement" to off and "Maximun DSP Block Usage" to zero, but it doesn't work. The compilation still used the DSP BLOCK. Did I miss anything?
