10 years agoQuestion about good design: overriding functions, function parameters or similar
Hi, Is in VHDL something similar to overriding a function or giving function as parameter to an entity (similar to c++ or javascript). I'm implementing some image processing components which...
10 years agoI put reusable code into VHDL functions and reuse them in processes. I understand how to provide different architectures for entities implementation and entity configuration concepts. The generate statement is not of big use because function defintion itself is actually not synthesised to anything as long as it's not used inside a process or signal assignment or similar. Actually something similar to configurations but for functions is what would help. e.g. You define function interface in the entity and can provide function implementation from outside similar to configuration of entities.
I will go with a global function and a generic parameter in enitity which selects what function is actually has to calculate. Thanks for input.
